My brother @ TamircihasSTK080 have made an amplifier with a nice supply of Anfi is symmetric 2 × 24 volt 60 watt transformer can use
Friends of amplifier circuit printed circuit boards has been prepared by me. Circuit gain and excessive background noise is reduced to 22 to prevent deportation circuit is now working smoothly. After installing the transformer circuit with the circuit between the diode bridge will connect only 6 amp filter capacitors that are on the circuit.
STK080 30Watt Amplifier
STK080 AF output power amplifier
THD=0.3%, f=20 to 2OkHz
Recommended supply voltage + – 27 volt
Maximum supply voltage + – 39 volt
STK080 Amplifier proteus ares pcb file:
STK080 Amplifier Project
Publication date: 2009/01/25 Tags: audio amplifier circuits, ic amplifier
12V to 320V DC DC Converter MC34063 High-Power
MC34063 (njm2360) and 12V input 320V output dc dc converter circuit guess a small 37 inch television run, but such an application to experiment with I output of the circuit to be isolated because of how the results do not know what more to be mixed and less material is used for the short time I’ll try a circuit for MOSFET 2SK3131 2SK3132 or used ..
MC34063 320V DC DC Converter Schematic
