TDA1560Q is an integrated bridge amplifier operating in class B and H. The amplifier is able to deliver load power 8W 30W at maximum distortion of 0.5% (40W; THD = 10%). The supply voltage of the amplifier is in the range of 8 to DC 18V with maximum demands in the supply branch 4 – 6A. With a supply voltage range 8- 18V circuit is predestined to design amplifiers for cars. The voltage gain amplifier is 30 db at 55 db channel separation. Input impedance is 100 – 300kW. The integrated circuit is housed in a casing SIL17 that can be compactly mounted on
TDA1560Q Amplifier Circuit Parameters
· Very high power output
· Low power dissipation without music signal
· Minimum of external components
· MODE function (MUTE, STANDBY, Class-B, Class-H)
· Thermal, short-circuit and overcurrent protection
· Diagnosis circuit (output DIAG)
· Fixed voltage gain (30 db)
· Short-circuit resistance to ground, supply voltage and the output terminals
TDA1560Q Schematic Diagram
TDA1560Q that caught my attention at first glance, so I went into his design and construction. If you do not have adjustable frequency signal source, so we have to tackle building volume control and correction, which has been on the Internet and in described by many magazines, so I do not mention.
2X40W Amplifier TDA1560Q PCB schematic files download:
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-25319.zip
Publication date: 2014/03/04 Tags: audio amplifier circuits, ic amplifier
ATmega16 Analog-Looking Digital Clock Project
Atmega16 microcontroller in our circuit monitor 7 inch in size. Screen “3 inch” or “4 inch” may be, it doesn’t matter. We have the biggest screen by controlling the foot links we could find.
In circuit 7805 voltage regulated chip. 9 Volt battery restraints when it integrated provides the proper functioning of the circuit elements, constants and 5 volts.
Proteus isis circuit diagram;
2X40W Verstärker Schaltung TDA1560Q
TDA1560Q ist eine integrierte Brücke Verstärker zum Betrieb in Klasse B und H. Der Verstärker ist in der Lage zu liefern, laden, macht, 8W 30W bei maximaler Klirrfaktor von 0,5% (40W; THD = 10%). Die Versorgungsspannung der Verstärker ist im Bereich von 8-18V DC mit maximalen Anforderungen in der supply-Zweig 4 – 6A. Mit einem Versorgungsspannungsbereich 8 – 18V Schaltung ist prädestiniert für die design Verstärker für Autos. Der Spannungsverstärkung Verstärker 30 db auf 55 db Kanal-Trennung. Eingangsimpedanz 100 – 300kW. Die integrierte Schaltung befindet sich in einem Gehäuse SIL17 werden kann kompakt montiert auf
