The TA2022 is a 90W (4Ω) continuous average per channel Class-T Digital Audio Power Amplifier IC using Tripath’s proprietary Digital Power Processing (DPPTM) technology. ClassT amplifiers offer both the audio fidelity of Class-AB and the power efficiency of ClassD amplifiers. Class-T architecture High Power
100W @ 4ohm, 1.0% THD+N
90W @ 4ohm, 0.1% THD+N
60W @ 8ohm, 0.1% THD+N
Audiophile Sound Quality
0.015% THD+N @ 70W 4ohm
0.015% THD+N @ 45W 8ohm
0.10% IHF-IM @ 25W 4ohm
High Efficiency
92% @ 88W 8ohm
87% @ 125W 4ohm
Dynamic Range = 102 dB
Mute Input
Integrated Gate Drive Supply
Over-current protection
Over and under-voltage protection
Single ended outputs
Outputs can be operated in bridged mode
32-pin SSIP package
APPLICATIONS
Mini/Micro Component Systems
Home Theater Receivers
Car stereo head units & trunk amplifiers
Powered DVD Systems
B E N E F I T S
More power per cubic inch for 100W per channel design
Simplifies thermal management
Signal Quality comparable to linear amplifiers
Simple building block for multi-channel design
FEATURES
High Power: 100W @ 4ohm 1.0% THD+N
Low Noise Floor: 150uV A-weighted
Low Distortion: .02% THD+N @ 75W, 4ohm
High Efficiency: 92% for 8ohm loads
Dynamic Range = 102dB
Over-Current Protection
Over and Under Voltage Protection
Over Temperature Protection
Single Ended Outputs
source moxied.com
2X100 Watt Class-T Amplifier Circuit TA2022 pcb scchematic;
Publication date: 2008/01/11 Tags: audio amplifier circuits, ic amplifier
Cheap Simple PIC EEPROM programming Circuits
PIC EEPROM for those dealing cheap simple programming circuits circuits on the computer RS232 COM port works through external power supply does not require a circuit between the very large differences do not suit your needs choose the one that will make you to the people who come easy
2X100 Watt Class-T Verstärker Schaltkreis TA2022
Der TA2022 ist ein 90W (4Ω) kontinuierlicher Durchschnitt pro Kanal Class-T Digital Audio Power Amplifier IC mit Tripaths proprietärer Digital Power Processing (DPPTM) Technologie. ClassT-Verstärker bieten sowohl die Audio-Treue von Class-AB als auch die Leistungsfähigkeit von ClassD-Verstärkern. Klasse-T Architektur Hochleistungs
