The Far East quite a popular hi fi BJT transistor amplifier module for full power output transistors 4 2SC 5200 and 2S 1943 should be tested one at each used test voltage +-35v accordingly, the power will be lower for full power supply voltage pretty high, build and test stages be careful of capacitors and transistors link circuit voltage without checking whether it is correct to give.
Maximum supply voltage + / – 95V.
Output power 255W RMS 8 Ohm speaker with 4 ohm speakers with 400W RMS
Frequency Response 20Hz – 20Khz
Input Sensitivity 1.25V RMS
Input impedance 39 pounds. ohms.
400-Watt Power Amplifier Module
Publication date: 2009/09/22 Tags: audio amplifier circuits, transistor amplifier
SAAA1057 BH1417 15W FM Stereo Multiplex PIC16S819 Control
Stereo Multiplexing for FM circuit pic16f819 saa1057 bh1417 integrated based on the basic prepared with source software’s (. Bas) circuit diagrams and material list has pcb drawing no different practice pic microcontroller with PLL FM applications for a sample project also antenna drawings and formulas given
