In particular, a lot of people dealing with television repair business that would work with an EEPROM circuitry in copying a one-to-one can copy my eepromu.
Copy circuit Atmel AT90S2313 built on a beautiful application PBC and. Hex. Thousand source files have the monitor television from various devices like 24xx series EEPROM using frequent failures of devices performing eprom files kpyalayıp backup can take a solid archives can create
EPROM copier
The device “Reader” (hereinafter referred to simply as “device”) is a standalone device designed to work with nonvolatile memory EEPROM chips with I2C protocol tires 24 xx series and their analogs The device allows for reading, writing, editing these chips, as well as chips proshitoy comparison with the original.
source master-tv.com EEPROM copier circuit alternative link:
Publication date: 2008/02/18 Tags: avr development board
ATMEGA168 Mood Poly Controlled Interactive LED Light
“Polycontrolled Interactive LED Mood Light” is based on Atmel ATMEGA168/88 quite a strange RGB LED application design professional as well as various modes, speed, the program’s options.
I hope I know the main parts used in the market are located
LMC6482 (National Semiconductors, DIP8), LIS2L02AS4-TR (ST, SOIC 24), MAX712CP A + (Maxim / Dallas, DIP 16), ATMEGA168/88 (Atmel, DIP 28), MAX603CS A + (Maxim / Dallas, SOIC 8), HMC6352
