Circuit have not tried but proteus isis on the set up and necessary to try other resistor capacitor limiting circuit according to looks better than circuit 123 pcs white LED 230v mains voltage rectified dc voltage is being run with + voltage directly to the LEDs – the BD711 and BC547 transistors goes out.
CAUTION Be careful is working with high voltage capacitor circuit connections Beware + – If you connect the high voltage polarity may be large explosions before running the insured Power Line circuit, protective goggles
Transformerless LED Lighting Lamp Circuit 230V
Source: http://elwo.ru/publ/skhema_svetodiodnoj_lampy/1-1-0-217
Publication date: 2010/09/22 Tags: analog circuits projects, led projects
Mixed LED Lighting Circuits LEDs Project
LED technology is now being used in many places. Lighting, LEDs for illumination mixed circuits, LED circuits LED table lamp, LED flashlight, the MOSFET current limiting circuits etc. LED lighting. tried a lot of mixed simple circuit has 17 LEDs. In addition to the LED control circuit MOSFET transistor with the transferor’s LEDs.
LED Circuits Lighting Project
