200W Amplifier Low High Bass Control TIP3055 TIP2955
| Updated on March 14, 2024
Output transistors in the 200W Amplifier circuit are TIP2955 and TIP3055. Working voltage is 2X42V DC symmetrical (2X30V AC). Power supply rectifier, filter, fuses, amplifier and low high bass control layer are on a single PCB. TL084 Op amp is used for the low high bass circuit, you can make the selection with the switch on the card and adjust the frequency with the potentiometer.
There are PCB Gerber and PDF files for the 200W Amplifier circuit.
200W Amplifier TIP3055 TIP2955 Circuit Diagram
tl084-low-bass-and-high-controller-schematic-circuit-diagram
schematic-zenor-amplifier-zenor-amlifier-low-bass-high-bass-tl084
pcb-layout-tip3055-tip2955-amplifikator-200w-low-high-bass-kontrol-board
Publication date: 2024/03/14 Tags: ,
1 Comment “200W Amplifier Low High Bass Control TIP3055 TIP2955
  1. QamarQamar
    Hi sir I am finding a 500watt MOSFET audio amplifier 48+48 volt
