SG3525 EI33 200w-600w ATX DC DC Converters Circuits
| Updated on July 4, 2023
@ Tahir brother’s a nice project, pc power supply transformer carried out with a 12 volt input voltage of 2 × 55 .90 volts + – symmetric voltage is turning circuit sg3525 PWM control IC used this SMPS circuit in your car, you want to use with high voltage running amp power supply is ideal for even transformer winding never have to worry 🙂
Caution: Be careful of the circuit output voltage is high, you must take the necessary measures
There are two versions of Project 200 watts and 600 watts for dual 600w power supply disconnected from two computers using the EI33 transformer and MOSFET (IRFP064N) 4 used
PC Power supply disconnected from the power transformer transformer ei33 link photos while out in the picture below will unveil +12 v 5v end is connected to the ends of the MODFET
DC-DC Converter Circuit Diagram
dc-dc-atx-circuit-diagram
atx-trafo-ei33-acilimi-dcdc-icin-kullanim
200w and 600w dc converter circuits photos;
atx-ei33-dcdc-200w-smps-sg3525-2
smps-dual-600w-power-supply-car
powersupply-circuit-ei33-dcdc-200w-smps-sg3525-120x120 smps-dual-600w-120x120 smps-test-dcdc-120x120 switch-mode-circuit-ei33-dcdc-200w-smps-sg3525-120x120
200w and 600w dc circuit PCBs (. LytA + bmp Proteus ares) files:
Publication date: 2008/02/20 Tags: , ,
12 Comments “SG3525 EI33 200w-600w ATX DC DC Converters Circuits
    12V 10V Siren Circuit
    “12 Volt 10 Watt Siren Circuit” in various shades with integrated UM3561 (police, ambulance, fire) 10w 12volt power supply and siren circuit
    The integrated circuit’s supply 3 volts and 5 volts for the 3.3 volt zener regulated by supply made
    SG3525 EI33 200 W-600 W ATX-DC-DC-Wandler-Schaltungen
    @ Tahir Bruder ist ein schönes Projekt, PC-Netzteil Transformator mit einer Eingangsspannung von 12 Volt von 2 × 55,90 Volt + durchgeführt – symmetrische Spannung Wendeschaltung SG3525 PWM-Steuer-IC verwendet diese SMPS-Schaltung in Ihrem Auto, mit dem Sie verwenden möchten Hochspannungs-Laufverstärker-Netzteil ist ideal für selbst Transformatorwicklungen, keine Sorge 🙂
    Achtung: Achten Sie darauf, dass die Ausgangsspannung des Stromkreises hoch ist. Treffen Sie die erforderlichen Maßnahmen
    Es gibt zwei Versionen von Project 200 Watt und 600 Watt für zwei 600-W-Netzteile, die mithilfe des EI33-Transformators und des verwendeten MOSFET (IRFP064N) 4 von zwei Computern getrennt wurden
    PC-Stromversorgung getrennt vom Leistungstransformator Transformator EI33 Link Fotos, während in der Abbildung unten enthüllt +12 V 5V Ende ist mit den Enden des MODFET verbunden
  3. DurontoDuronto
    Hello, How do you calculate the output inductor if you have any formula pls share
    1. gevvgevv Author
      H,
      Output inductor in atx power supply circuit used.
      Materials (power transformer, output inductor) were remove from the PSU board.
