Detail of a project from start to finish guitar fuzz effects, making the circuit box to print pictorial effect has been demonstrated circuit consists of two transistors and a few passive components are drawing pcb upside down. In addition to appearing in the block diagram circuit enriched with other floors.
Fuzz Face Circuit
source: guitariste.com
Publication date: 2009/10/11 Tags: audio control circuits
3-Axis PC Parallel Port Stepper Motor CNC Control Circuit
At the output of integrated circuit based on the 7409 L297 Used IRLZ14 (12 pieces) is being MOSFETs. Computer connectivity is provided via the parallel port
For control Cnfrais to, Kellyca, I Cncpro, WinPCNC, Desknc programs mentioned parallel port support that you know CNC softwares in use in pdf format pcb, schema files are also the source protel 98 dosyalarıda’s (. Schema,. Pcb)
3 Axis PC LPT Stepper Motor Control
