1W Amplifier with TDA2822M Stereo
| Updated on August 4, 2019
The 1 watt audio amplifier circuit presented here uses the famous TDA2822M integrated circuit, which is one of the most integrated amplifiers used in conventional PC. This integrated can deliver a maximum power of 600 milli-watts per channel, for a total of 1.2 watts.
The integrated circuit TDA2822M is a stereo amplifier in 8-pin type encapsulated MINIDIP. Its most common use is as an amplifier in radios, small game consoles, home computer speakers, among others.
TDA2822M 1W Amplifier Schematic Diagram
tda2822m-schematic-diagram-stereo
tda2822m-integrated-circuit-audio-amplifier
You can work with voltages from 3 volts to 12 volts DC. Of course, if you plan to use it as a headphone amplifier is not necessary to use such high voltages. With 5 volts is more than enough. However you can work with speakers and the voltage of 5 volts delivering the computer USB port and you get a nice sound.
source: construyasuvideorockola.com 1W Amplifier circuit PCB alternative link:
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-25275.zip
Publication date: 2014/03/02 Tags: ,
2 Comments “1W Amplifier with TDA2822M Stereo
    Li-Ion Charger Application Notes
    1-Analog Design Note: Charging Simplified for High Capacity Batteries (Microchip Technology)
    2-Analog Design Note: A Li-Ion battery charger using tsm102a (STMicroelectronics)
    3-Analog Design Note: Li-Ion battery charger Reference Design Li-Ion battery charger Demonstration Board using LM3647 (Texas Instruments)
    4-Analog Design Note: Charging Lithium-Ion/Lithium-Polymer Batteries Power Management (Microchip Technology)
    5-Analog Design Note: Switch-mode charging topology Charging Li-ion Batteries for Max. Times (Microchip Technology)
    1W Verstärker mit TDA2822M
    Die 1-watt-audio-Verstärker-Schaltung vorgestellt, die hier verwendet die berühmte TDA2822M integrierte Schaltung, die eine der am stärksten integrierten Verstärkern, die in herkömmlichen PC. Diese integrierten liefern eine maximale Leistung von 600 milli-Watt pro Kanal, für eine Gesamtmenge von 1,2 Watt.
