3V LEDs run on 1.5V batteries
| Updated on June 22, 2014
White Led dc converter circuit for a simple two transistor drive again with no trouble winding transformer coil output filter instead I used the PC power supply when there is such a great resource who is involved.
1-5volt-dcdc-convertor-dc-dc-cevirici-120x120 3volt-dc-dc-anahtarlamali-power-120x120 dcdc-3volt-konvertor-120x120
DC to DC converter circuits used in computer power supply coil -5 and -12 volt output filter coil I pulled is negative.
power_atx
lcr_metre
orjinal_converter_dcdc_led_battery-120x120 modifiye_converter_dcdc_led_battery-120x120 dc-dc-pil-led-devresi-120x120
Publication date: 2008/02/09 Tags: , , ,
2 Comments “3V LEDs run on 1.5V batteries
    High Power 2200W Amplifier Circuit
    2200W High cost an amplifier project if you want to go ahead kck87 our friend minding 2200w amp circuit Proteus ares with PCBs have drawn 56 IRFP250 Mosfets used supply voltage is too high (+-150V) Be careful circuit now has not been tested. 2200W amplifier circuit drawing extension’s source has pcb ares proteus ..
    Weiße LED-Gleichstromwandlerschaltung für einen einfachen Zwei-Transistor-Antrieb ohne Probleme beim Wickeln des Ausgangsfilters der Transformatorspule Stattdessen habe ich das PC-Netzteil verwendet, wenn eine so große Ressource betroffen ist.
