DC-DC converter circuits operating frequency of 40Khz input voltage output voltage of 24 volts to 12 volts and 1.5 amps of power efficiency of 90% and max 10 mV ripple voltage is called the BUZ11 MOSFET power transistor
The oscillator circuit solid (BF240) transistor flip flop circuit before I share the same values, only the material is different and there are a few additions. The circuit diagram pcb’s drawing and material list
12V 24V DC to DC converter
Published: 2009/11/01 Tags: dc dc converter circuit, power electronic projects
PICMicro LCD Bar Applications Hi Tech C and Proton ide Example
Greetings friends I share the LCD bar applications with C spelled my earlier application with basic proton HiTech C and I’ve taken this time.
In case that codes for functions can easily be adapted to the application. In addition, with minor changes in the other pic c compiler used. The links made with both basic and C applications can be downloaded.
Hi tech C example Lcd bar
