Now bring the involvement of voltage stabilizer with much greater efficiency, which will not significantly alter the value of the input voltage. step down converter. It is a source of switching, the so-called step down converter.
Many manufacturers have already produced a special integrated circuits, which brings together budic, power transistor and feedback controls output voltage and output current limiting. For example, National Semiconductor LM2574 producing districts, LM2594 and LM2597 for switching resources with output current 0.5 A further LM2575, LM2595 and LM2598 for a maximum output current 1A and likewise for higher currents. For enlightenment dashboard motorcycle through switching diodes will suffice regulator with the limitations of current output to 1A.
LM2575TADJ DC DC Converter Circuit
LM2575T-ADJ Switching Regulator DC to DC Converter Circuit schematic pcb alternative link:
Password: 320volt.com
Published: 2008/08/18 Tags: dc dc converter circuit, power electronic projects
Atmel ATMEGA8 IR detector circuit
8-channel approach to IR detector sensor circuit is realized with ATmega8 microcontroller. I2C bus (TWI, SMBus) are measuring through the obstacle detection, designed for mobile robot. Approach reflects the beam of infrared light detector circuit based on monitoring works.
8-channel detection information;
Measuring principle: Infrared light reflection Detection
Max. Sensor: 8 independent sensor
Communication interface: I2C – 7bit address
Module size: 78 x 62 mm (3 “x 2.44”)
Measuring the number of degrees: 3 distance levels (Min, Mid, Max)
Supply voltage: +5 V (DC)
Current consumption: 15 mA
Microprocessor: ATMEGA8 ATMEL (AVR – 8MHz)
