Excellent Led Ball Circuit ATmega88
| August 3, 2019 Updated
Great design has been providing birthday gifts as does not prepare mention Led to control atmega88 microcontroller is used ports çoklayıp LEDs milk to 74HC595 used LEDs effect has been very welcoming approximately 256 units LEDs with a one-compliant works. PCB LEDs are placed perpendicular to the semicircular cut and soldered LEDs formed by the card. (PCBs using thin twisted round to take shape provided)
Supply circuit provided with two alkaline batteries with integrated battery voltage converters max1674 dcdc given to upgrading the circuit.
The project started PCAD2006 pcb, diagram drawing and resource c, hex codes are ..
led-leds-atmega88-max1674-74hc595-led-ball
Source: radiokot.ru/circuit/light/run/45/ Alternative link: + PCAD2006 Viewer
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-19065.zip
Published: 2012/06/12 Tags: , ,
1 Comment “Excellent Led Ball Circuit ATmega88
    Hand-held Simple Magnetized Demagnetize Device
    Workshop also especially when trying screwdriver is magnetized, magnetized to be my job very olaylaştırıy I’m sure a lot of people in the same thoughts as me are but sometimes in different jobs that magnetize magnetizing event my work can make it difficult in general collet, tweezers work I would have no problem …
    I screwdriver to magnetize always in the corners standing speaker magnet I use the screwdriver magnetization decreases, the speakers took the business to continue but magnetized De-magnetizing device would be more portable .. device made ​​extremely simple very little material is used 1pc 1n4007 diode, coil and two-position switch writer 230v for use with coil windings of the motor has been running in this engine are from the laminator
