BTJ type power amplifier module 2SC5200 NPN transistors can take a 6 and 6 2AS1943 connected. PCB design simple, not too complicated input and output connections Serenity … 30mA of current 25 to be set
Symmetrical circuit supply voltage 90V DC +-75V is available ….
CAUTION 1000w amp module is working with high voltage capacitor connection Observe caution + – If you connect the high voltage polarity may be large explosions before running the insured Power Line circuit, protective goggles
Published: 2011/08/20 Tags: audio amplifier circuits, transistor amplifier
12V Lipo battery Pack Voltage Follower Circuit
LiPo (lithium polymer) batteries, especially cars, ships, etc. .. many models used in the cells are 3.7v because three or more coupled in series to the proper voltage is being achieved most widely used package 12V ones for this three lithium-polymer lipo battery series is connected but in series of batteries balanced charging required for this balance or balancing charge are circuits this circuit is in addition to battery voltage condition used to monitor connected to the batteries any 3v falls under the circuit buzzer sound is giving.
