Weller Soldering Adjustable Temperature Control Circuit
| Updated on July 19, 2023
Technical document of the Weller ec2002 heat regulated soldering iron. The control circuit is based on the LF353N and SL443A ICs, and the power control is provided by the TIC225M triac.
Besides the temperature control card of the Weller ec2002 soldering iron, there is an additional display card for display. Heat detection is provided by the Thermocouple sensor in the soldering iron.
In the display section, 3 7 segment displays (MAN71A) are used. There are heat control and display driver CA3161E circuit diagrams and pcb drawings.
Weller EC2002 Circuit Diagram
schematic-weller-ec2002-circuit
schematic-display-driver-weller-ec2002-circuit
Weller Soldering Adjustable Temperature Control Circuit :
Publication date: 2009/05/10 Tags:
1 Comment “Weller Soldering Adjustable Temperature Control Circuit
    Multi-functional PICmicro Development Board (Breadboard Supported)
    quite an advanced picmicro trial, testing, project development cycle a lot of functions all resources shared also the circuit for testing c language prepared test program at (pıc_board_test.c) had the most excellent on the PCB Breadboard for the installation department leave have pic development circuit 7805 with a volt supply voltage dc 12v or 9v adapter leveling feature can run with
