VU Meter Circuits LM3914 LM3916 LM3915
| Updated on June 30, 2023
LED VU Meter LM3914, LM3915, LM3916 LED driver dot bar display made ​​with a variety of integrated circuits vu meter circuit can use with normal 3mm LEDs 5mm LEDs as well as a bar have used modules are located in the meter has been deactivated
Sprint Layout PCB file the prepared project with a well-designed double-sided PCBs used 4 integrated LED bar display while the
Eagle PCB and schematics files prepared with a drawing program finished version of the project
lm3915-lm3916-vumetre-pcb-sprint-layout1
lm3914-vu-metre-devresi-eagle
lm3914-lm3915-lm3916-dot-bar-display-driver
LM3915 LM3916 – Dot Bar Display Driver
The LM3916 is rated for operation from 0°C to +70°C. LM3916N-1 is available in an 18-lead molded DIP package.
  • Fast responding electronic VU meter
  • Drivers LEDs, LCDs, or vacuum fluorescents
  • Bar or dot display mode externally selectable by user
  • Expandable to displays of 70 dB
  • Internal voltage reference from 1.2 Volt to 12 Volt
  • Operates with single supply of 3 Volt to 25 Volt
  • Inputs operate down to ground
  • Output current programmable from 1 mA to 30 mA
  • Input withstands ±35V without damage or false outputs
  • Outputs are current regulated, open collectors
  • Directly drives TTL or CMOS
  • internal 10step divider is floating and can be referenced to wide range of voltages
LM3914 – Dot/Bar Display Driver
  • Drives LEDs, LCDs or vacuum fluorescents
  • Expandable to displays of 100 steps
  • Internal voltage reference from 1.2Volt to 12Volt
  • Operates with single supply of less than 3Volt
  • Output current programmable from 2 mA to 30 mA
  • No multiplex switching or interaction between outputs
  • LED driver outputs are current regulated, open-collectors
  • Outputs can interface with TTL or CMOS logic
VU Meter Circuits pcb schematic files:
Publication date: 2008/01/12 Tags: ,
2 Comments “VU Meter Circuits LM3914 LM3916 LM3915
    Counter Circuits with PIC16F628 PIC16F84 PIC16F877
    PIC16F877, PIC16F84, PIC16F628 microcontroller software is based on the counter circuits pic-assembly prepared with PicBasic pro
    Circuits able to count from 0 to 9999 source code reengineer isis oluşturulabilit different working modes. Dns files there can simulate circuits
    0-9 0-99 PIC16F877 pic basic matrix counter, with 3 Digit counter PIC16F84 UpDown
    PIC16F628 with LCD Programmable counter
    Counter Circuit Examples
    VU-Messkreisläufe
    VU-Messschaltungen LM3914 LM3916 LM3915
    LED-VU-Meter LM3914, LM3915, LM3916 LED-Treiber-Punktbalken-Display mit einer Vielzahl von integrierten Schaltkreisen vu Meter-Schaltung kann mit normalen 3 mm-LEDs verwendet werden 5 mm-LEDs sowie ein Balken verwendet Module befinden sich im Meter wurde deaktiviert
    Sprint Layout PCB Datei das vorbereitete Projekt mit einer gut gestalteten doppelseitigen Leiterplatte verwendet 4 integrierte LED-Balken-Anzeige, während die
    Eagle PCB- und Schaltplan-Dateien, die mit einem Zeichenprogramm erstellt wurden, sind die fertigen Versionen des Projekts
    VU-Messschaltungen LM3914 LM3916 LM3915 lm3915 lm3916 Leiterplatten-Sprint-Layout1
    VU-Messschaltungen LM3914 LM3916 LM3915 lm3914 vu meter devresi eagle
    VU-Messschaltungen LM3914 LM3916 LM3915 lm3914 lm3915 lm3916 Punktbalken-Anzeigetreiber
    LM3915 LM3916 – Treiber für Punktbalkenanzeige
    Der LM3916 ist für einen Betrieb von 0 ° C bis + 70 ° C ausgelegt. Der LM3916N-1 ist in einem 18-poligen DIP-Gehäuse erhältlich.
    Schnell reagierendes elektronisches VU-Messgerät
    Treiber LEDs, LCDs oder Vakuumfluoreszenzmittel
    Balken- oder Punktanzeigemodus kann vom Benutzer extern ausgewählt werden
    Erweiterbar auf Anzeigen von 70 dB
    Interne Spannungsreferenz von 1,2 Volt bis 12 Volt
    Arbeitet mit einer Stromversorgung von 3 Volt bis 25 Volt
    Die Eingänge arbeiten auf Masse
    Ausgangsstrom programmierbar von 1 mA bis 30 mA
    Der Eingang hält ± 35 V ohne Beschädigung oder falsche Ausgänge aus
    Ausgänge sind stromgeregelte, offene Kollektoren
    Treibt direkt TTL oder CMOS an
    Der interne 10-Stufen-Teiler ist potentialfrei und kann auf einen großen Spannungsbereich bezogen werden
    LM3914 – Treiber für Punkt- / Balkenanzeige
    Steuert LEDs, LCDs oder Vakuumfluoreszenzmittel
    Erweiterbar auf Anzeigen von 100 Schritten
    Arbeitet mit einer Stromversorgung von weniger als 3 Volt
    Ausgangsstrom programmierbar von 2 mA bis 30 mA
    Keine Multiplex-Umschaltung oder Interaktion zwischen den Ausgängen
    LED-Treiberausgänge sind stromgeregelte Open-Collectors
    Die Ausgänge können mit TTL- oder CMOS-Logik verbunden werden
