RJ45 UTP cable test, there are two different circuits to control the strength of the circuits made with PIC asm code and the PCB (circuit 2) files have our own UTP RJ45 Cable Tester Make your device
The only difference is almost a one identical circuits used in microcontrollers circuit PIC16F627-04 used a basic passive circuit elements, a few resistors and diodes LEDs
RJ45 UTP Cable Tester Circuits PIC16F627 PIC16F84 source code pcb schematic
Publication date: 2008/01/13 Tags: microchip projects, microcontroller projects, pic16f84 projects
High quality guitar amplifier circuit TDA7294
DMOs TDA7294 integrated amplifier guitar amp used for a variety of powerful sound, the tone control circuit TL071, TL072, TL074 op-amp ICs used
Voice in the introduction of control quite well GAIN, HI-MID, LOW-MID-BASS, TREBLE, VOLUME settings are all enabled electronic kompadent commercially available but quality potency little hard to find 4-ohm speakers and 2 x 12 volt supply voltage and 70watt power gives for 8 ohm speakers you can get 2 × 20 volt transformer power supply circuit using a full bridge diode used in place of 6 amps to me seemed a bit weak, I suggest using the bridge-diode
RJ45 UTP Kabel Tester Schaltungen PIC16F627 PIC16F84
RJ45 UTP-Kabeltest, gibt es zwei verschiedene Schaltungen zur Kontrolle der Stärke der Schaltungen mit PIC-Code gemacht und die PCB (Schaltung 2) Dateien haben unsere eigenen UTP RJ45 Kabel Tester Machen Sie Ihr Gerät
Der einzige Unterschied ist fast eine ein identische Schaltungen verwendet in Mikrocontroller Schaltung PIC16F627-04 verwendet eine grundlegende passive Schaltung Elemente, ein paar Widerstände und Dioden LEDs
