455 kHz Oscillator Circuit
| Updated on July 12, 2023
3 transistors are used (bc548) supply voltage is 9 volts 455kHz RF signal is produced with ceramic crystal.
Description of the circuit
The 455kHz Modulated Oscillator generates an amplitude modulated 455kHz carrier waveform with a 500Hz tone. You can use it to align the intermediate frequency (IF) stages of any AM broadcast or shortwave radio.
This project generates amplitude modulated 455kHz RF signal. It can be used to accurately align the intermediate frequency stages of heterodyne AM receivers.
rf-osilator-devre-semasi-rf-devresi
If you are going to build the Aussie 3-Valve Radio described in this issue or are involved in restoring old radios, you will want to correctly align the IF stages of this Minispot 455kHz modulated oscillator. For readers with long memories, it looks a lot like the Minispot circuit published in the February 1981 issue of “Electronics Australia” magazine.
The goals of IF alignment are to ensure that all tuned circuits in the IF stages are tuned to the same frequency and that this frequency is the correct frequency, usually 455 kHz.
If the various parts of the IF stages are tuned to different frequencies, the sensitivity of the receiver is poor. It may also encounter unwanted loud whistles at the sound output. Therefore, correct IF compatibility is essential for good performance.
Oscillator Circuit
455khz_rf_osilator
Source: http://www.siliconchip.com.au/cms/A_109838/article.html
455kHz Oscillator Circuit pcb schematic alternative link:
Publication date: 2008/09/03 Tags:
1 Comment “455 kHz Oscillator Circuit
