AVR Temperature Measurement System
| Updated on July 2, 2023
Atmel AVR, Atmel microcontroller series with a super “Temperature Control Measurement System” 16 sensor inputs 4 alarm inputs and the computer’s connection. Temperature measurement, alarm, an exemplary application in the PC communication
This measuring system is used to record the data of up to 24 temperature sensors in the range of -55 ° C to +125 ° C, 3 humidity sensors and an air pressure sensor. Addition, there are still 4 alarm inputs are available, where switching contacts can be connected. The project consists of several components: the sensor module 2, the sensor module 3 with additional air pressure sensor, the small display module 1, the large display module 2a, the LED display module 3 and the PC program “AnzKom” and a web module.
The sensor modules record the temperatures and humidities over 1-Wire sensors and monitor the alarm inputs. The processed data are then sent cyclically via an RS-232 interface to the display modules, which in the case of the display module 2a can also record the data represents a clear and. With the “AnzKom” program can be transferred, conveniently displayed and analyzed the stored data of the display module 2a. The Web module also provides the ability to query current and stored data via web-browser world.
ATmega128-240x128-glcd-grafik-lcd-120x120 Projekt-Temperatur-Messsystem-Anzeige-modul-atmel-avr-atmega-120x120 tempmess-display-ATmega16-120x120
project-temperature-measurement-system-overview-of-the-system
The first sensor module MAX232CPE, atmega8l-8 and consists of LPT parallel port section. The second sensor module 2X20 lcd screen, ATmega8, MAX232CPE and LPT parallel port consists of sections.
The display module display module-2-one AT90S2313 ATmega128 24c512, LM358, PCF8583, MAX232, lm2575, RS232, 240 × 128 graphic LCD display module-3 8 display, ATMega16
Source : s-huehn.de AVR Temperature Measurement System files Alternative link:
Publication date: 2008/01/13 Tags: ,
2 Comments “AVR Temperature Measurement System
    PIC18F2455 OBD2 USB to RS232 converter circuits
    USB-to-RS232 converter on desktop computers COM port does not work well, but most of them are not useful for notebook laptop com-port Serial not found. Based on PIC18F2455 microcontroller circuit diagram hex driver software and observation programs there.
    Atmel AVR, Atmel-Mikrocontroller-Serie mit einem hervorragenden „Temperature Control Measurement System“. 16 Sensoreingänge, 4 Alarmeingänge und der Computeranschluss. Temperaturmessung, Alarm, eine beispielhafte Anwendung in der PC-Kommunikation
    Mit diesem Messsystem werden die Daten von bis zu 24 Temperatursensoren im Bereich von -55 ° C bis +125 ° C, 3 Feuchtesensoren und einem Luftdrucksensor erfasst. Zusätzlich stehen noch 4 Alarmeingänge zur Verfügung, an denen Schaltkontakte angeschlossen werden können. Das Projekt besteht aus mehreren Komponenten: dem Sensormodul 2, dem Sensormodul 3 mit zusätzlichem Luftdrucksensor, dem kleinen Anzeigemodul 1, dem großen Anzeigemodul 2a, dem LED-Anzeigemodul 3 und dem PC-Programm „AnzKom“ sowie einem Webmodul . Die Sensormodule erfassen die Temperaturen und Luftfeuchten über 1-Wire-Sensoren und überwachen die Alarmeingänge. Die verarbeiteten Daten werden dann zyklisch über eine RS-232-Schnittstelle an die Anzeigemodule gesendet, die im Falle des Anzeigemoduls 2a auch die Daten übersichtlich aufzeichnen und darstellen können. Mit dem Programm „AnzKom“ können die gespeicherten Daten des Anzeigemoduls 2a übertragen, komfortabel angezeigt und analysiert werden. Das Webmodul bietet auch die Möglichkeit, aktuelle und gespeicherte Daten über eine Webbrowser-Welt abzufragen.
