At work I am running about 1 years charged with screwing screwing device in the market, cheap Cordless transformer 4.8 v, etc.. I mean, I guess it was a price, such as more batteries gave out already 15tl much yield did not expect occasional uses, but a permanent solution to the problem is to use sıklaşınca, I decided to run with the same transformer can be used in the system the Cordless screwdriver.
I get more torque and acceleration to a higher voltage transformer used with 7 .2V AC output I got this output is not reducing the secondary transformer 100w giving him unwrap his bandage after I added a 7 .2V level brought the diode bridge output I got 3 for TO220 case not fast diode 6a diode used (see; Schema) 7.2 v mains after about 6.4 v was exactly what I wanted, I’m using speed, power was smoothly.
Simple schema.
Publication date: 2013/08/06 Tags: interesting projects electronics
Current Limiting 230v LED bulb (Flux Led)
230v LED light bulb circuit of the 52 pieces of bright flux led directly to the current used in the Levant, a lot of working with mains voltage 30ma led lighting, led lamp circuits according to design more stable yield approximately 90% of the light flux power 5.6 w (estimated) 230 lm. the project applied an electronic magazine writer. Energy-efficient led light bulb project material list, printed circuit board, and schema drawings.
Akkuschrauber, die Ausführung mit Übertrager
Bei der Arbeit läuft bei mir über 1 Jahr berechnet mit Verschraubung Verschraubung Gerät auf dem Markt, billige Akku-transformer 4,8 v, etc.. ich meine, ich denke, es war ein Preis, wie mehr Batterien, die gab es schon 15tl viel Ausbeute nicht erwarten, dass gelegentlich verwendet, aber eine dauerhafte Lösung des Problems ist die Verwendung sıklaşınca, entschied ich mich, um mit dem gleichen Transformator kann verwendet werden, in das system der Akkuschrauber.
Bekomme ich mehr Drehmoment und Beschleunigung auf eine höhere Spannung Übertrager mit 7 .2V AC-Ausgang habe ich diese Ausgabe ist nicht die Verringerung der sekundären Transformator 100w ihm unwrap sein Verband, nachdem ich Hinzugefügt 7 .2V-Ebene brachte die Brücke aus dioden-Ausgang hab ich 3 für TO220 Gehäuse nicht schnell diode 6a-diode verwendet werden (siehe; Schema) 7.2 v-Netz, nach etwa 6,4 v war genau das, was ich wollte, bin ich mit Geschwindigkeit, Kraft war reibungslos.
