RGB Led Strip Extension Circuit
| Updated on August 4, 2019
Circuit used MOSFET N-Channel CSD18534KCS. I don’t think would be found in the market that may meet or beat irfz44 MOSFETs used can be different from R1, R2, R3 4.7 K resistors
Extension Led Strip
rgb-serit-led-uzatici-rgb-led-strip-extender
rgb-led-uzatici-devre-rgb-power
source: grix.it/viewer.php?page=11466 alternative link:
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-25457.zip
Publication date: 2016/04/23 Tags:
2 Comments “RGB Led Strip Extension Circuit
    PCB Tin Plating
    PCB printed circuit board lamination machine with pvc prepared at the end of the video on preparation of the practical printed circuit, solder in a manner that is rapid PCB coating is a useful method that I used when I was shown…
    in this video, tin coating PCB lemon salt and had been informed about metal roses in the boiling water melt coating of a substance called PCB is doing its job
    RGB-Led-Streifen Erweiterungs-Schaltung
    Schaltung MOSFET N-Kanal CSD18534KCS. Ich glaube nicht, dass würde man auf dem Markt finden, kann treffen oder schlagen irfz44 MOSFETs verwendet werden, sind Verschieden von R1, R2, R3 4.7 K widerstände
