Portable Battery welding Circuit (transformerless)
| Updated on March 20, 2019
Previously shared “Simple Electronic Battery welding circuit” projects an battery punctuation circuit easier than at least transformer winding. When triggered by the switch, the NE555 timer is used. When the SB1 button is pressed, the output is activated during the set time. This circuit can cause a failure of the MOSFET and the battery when voltage is applied for a considerable period of time. NE555 supply is supplied with 9v battery 5v 1a relay 5 parallel connected IRLB4132 controlling MOSFETs IRLB4132 instead of MOSFETs IRF1404, IRF1405, IRF1104, IRF1324
MOSFETs can be used High voltage power supply for battery puncture cycle 2 units 4400mA The 3.7V lipo battery is provided by connecting parallel.
ne555-power-pil-punta-pil-punta-devresi-pil-puntalama
A large cooler was not used as it provided instantaneous current control from the molds. All systems were mounted on pillars and connected to a parallel cable of 8 … 10 1.5mm for thick cable which would withstand high flux in puncture probes.
pil-punta-pil-punta-devresi-pil-puntalama-lipo-lion
Battery welding Circuit Schematic
pil-puntalama-devre-semasi-ne555-mosfet
Note: The PCB drawing is not shared. You can install a bredboard or perforated plate. If a PCB drawing is found, it will be added to the drawing if it is drawn.
Publication date: 2018/06/09 Tags:
6 Comments “Portable Battery welding Circuit (transformerless)
    Tragbarer Akku-Schweißkreis (transformatorlos)
    Die zuvor geteilte “einfache elektronische Batterie-Schweißschaltung” projiziert eine Batterie-Interpunktionsschaltung einfacher als zumindest eine Transformatorwicklung. Bei Auslösung durch den Schalter wird der NE555-Timer verwendet. Wenn die Taste SB1 gedrückt wird, wird der Ausgang während der eingestellten Zeit aktiviert. Diese Schaltung kann einen Fehler des MOSFET und der Batterie verursachen, wenn eine Spannung für eine beträchtliche Zeitdauer angelegt wird.
    NE555 Versorgung wird mit 9V Batterie geliefert 5V 1a Relais 5 parallel geschaltet IRLB4132 steuern MOSFETs IRLB4132 anstelle von MOSFETs IRF1404, IRF1405, IRF1104, IRF1324 MOSFETs können verwendet werden Hochspannungsnetzteil für Batteriepannen Zyklus 2 Einheiten 4400mA Die 3.7V Lipo Batterie wird von zur Verfügung gestellt Parallelschaltung
  2. projets de circuits electroniquesprojets de circuits electroniques
    Circuit de soudage de batterie portable (sans transformateur)
    Le «circuit de soudage de batterie électronique simple» précédemment partagé projette un circuit de ponctuation de batterie plus facile qu’au moins l’enroulement du transformateur. Lorsqu’il est déclenché par le commutateur, le temporisateur NE555 est utilisé. Lorsque le bouton SB1 est enfoncé, la sortie est activée pendant la durée définie. Ce circuit peut provoquer une défaillance du MOSFET et de la batterie lorsque la tension est appliquée pendant une période de temps considérable. Le NE555 est fourni avec une batterie 9v 5v 1a relais 5 IRLB4132 connecté en parallèle contrôlant les MOSFET IRLB4132 au lieu des MOSFET IRF1404, IRF1405, IRF1104, IRF1324
    Les MOSFET peuvent être utilisés Alimentation haute tension pour le cycle de perforation de la batterie 2 unités 4400mA La batterie lipo 3.7V est fournie en connectant en parallèle.
