Pickit2 dealing with using a lot of pic programming is still very popular pickit3 a factor in the late appearance of the version, though pickit 3 ICSP ZIF socket for pickit2 I have to wonder… has expanded to designs before pcb was shared at ICSP adapter ZIF socket for pickit 2 in the output module
@pwm.C will make your job quite easier for the teacher pickit3 ZIF socket pcb in your design work
note: adapter ICSP Pickit 3, 10F ,DsPIC, PIC32 series chassis and some old Bastards (such as 16f57) does not support.
In addition, the @meat my teacher Forum @EU ELECTRONIC made by a different design pickit3 icsp adapter pcb drawing
@AB ELEKTRONİK made by drawing: @pwm.C my teacher PICKIT3 ICSP Adapter ZIF the pictures above you can see the drawings designed by:
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-25411.zip
source: pwmccs.wordpress.com/2014/10/03/pickit-3-zif-soket-pcb/
etepic.com/index.php/topic,1185.0.html
Thank you to the people who contributed to prepare
Publication date: 2016/04/21 Tags: programmer circuit
Woofer Crossover Box Design Programs (Excel)
Jeff Bagby and Charlie Out great things with Excel, very detailed, active, passive crossover and woofer had prepared programs
Passive Crossover Designer
Excel application for designing passive crossovers and equalization The purpose of the this spreadsheet is to allow the user to accurately simulate the frequency, phase, and impedance of a two or three way speaker with crossover using imported data files of the actual measured responses. The data file types used correspond to Liberty Instruments “Imp” and “Audiosuite” frd type frequency response data, and zma /zda impedance data files. Sample data files have been included with this spreadsheet to allow the user to experiment and gain a better working knowledge of the program.
PICKIT-3 ICSP-Zwischenstecker Leiterplatte
Pickit2 Umgang mit einer Menge von pic-Programmierung ist immer noch sehr beliebt pickit3 ein Faktor, der in das späte erscheinen der version, obwohl pickit 3 ICSP ZIF-sockel für pickit2 ich Frage mich… hat erweitert, um designs für pcb wurde gemeinsam auf ICSP-adapter ZIF-sockel für pickit 2 in der output-Modul
