Development Board PIC18F2550 PIC18F4550
| Updated on August 3, 2019
PIC18F4550 and PIC18F2550 prepared for the experiment set of circuit than the regular seems simple, each chapter PCBs indicated on the layout also pretty good easily can be selected power source, LEDs, buttons, op amp LM35, EEPROM, relay, L293 motor drive, potency connections, ds1807 clock in addition there are sections in the header socket connections of the microcontroller’s port. pcb printed circuit drawing of the experimental set PIC18F2550 PIC18F4550 proteus ares prepared by the source. LytA files there.
pic18f4550-development-board-pic18f2550-development-board
pic18f4550-development-circuit-pic18f2550-development-circuit
Source: micros.mforos.com/1149907/6089366-construyendo-y-probando-la-tp-2550-placa-de-pruebas-para-usb alternative link:
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-19642.zip
Publication date: 2012/09/01 Tags: ,
2 Comments “Development Board PIC18F2550 PIC18F4550
    IR Protocol Analyzer Program
    ir Protocol Analyzer to use the sound card’s microphone input 1 x photo transistor connected to the controller, which uses the Protocol startbit, command, see the information on the program the address etc. information can also have graphic works export as the feature of “file” menu in the program installation without requiring the “samples” folder, you can examine the Protocol logs. Has source code for developers deplhi.
    Entwicklungskarte PIC18F2550 PIC18F4550 Leiterplatte
    PIC18F4550 und PIC18F2550 vorbereitet für den Versuch Satz der Schaltung als die regelmäßige scheint einfach, jedes Kapitel PCBs auf dem Layout auch ziemlich gut angezeigt kann leicht ausgewählt werden Stromquelle, LEDs, Tasten, Operationsverstärker LM35, EEPROM, Relais, L293 Motorantrieb, Potenz Verbindungen, ds1807 Uhr zusätzlich gibt es Abschnitte in der Header-Buchse Verbindungen des Mikrocontrollers Port. gedruckte Schaltung des Versuchsgerätes PIC18F2550 PIC18F4550 Proteus Ares von der Quelle vorbereitet. Lyt Leiterplatte Dateien dort.
