Hi All You Guys.
How long have you been working on CCS C. CCS will be able to see my level, so it is no longer something to do after arrival.
In this article, I made a small application on the USB communication pic18f4550. I really wanted to deal with the USB. A little uğraştırsada due to the short time for plenty of sample applications around USB thing figured out. I think there’s a common idea in dealing with USB. Because that I haven’t read about this article or the article. Well, first a couple of application korkutsada the USB after the eye really is different from rs232 communication in terms of convenience.
Now, my application
The system is very simple. Depending on the temperature the temperature sensor DS1820 Sıcaklık Sensorü RA5 pic18f4550, PIN information, and sends it to the computer via the USB port. For now only sends to the computer. I’m a little more for the novice yet C # form and showed the form only in order to show the temperature of the communication with the pic.
USB thermometer proteus isis circuit diagram
Vendor ID and ProductID information in the file is determined usb_driver.h. I did both: 0x1111 hex.
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-19631.zip
Publication date: 2012/09/01 Tags: microchip projects, microcontroller projects
Sd Card Sound Recording, Playback Circuit PIC16F876A
Audio recording circuit in addition to the Board upon a few passive pic16f876a microcontroller circuit is able to record onto sd card component was established to stop, play, record, pause, there are functions in addition to the audio input in the leg 2 pic16f876a preamp with the microphone can be connected. Audio recording circuit source PIC C and hex codes.
USB-Wärmemesser-Schaltung CCS C PIC18F4550
Hallo ihr Jungs.
Wie lange arbeitest du schon an CCS C. CCS wird mein Level sehen können, also ist es nach der Ankunft nicht mehr zu tun.
In diesem Artikel habe ich eine kleine Anwendung auf der USB-Kommunikation pic18f4550 gemacht. Ich wollte wirklich mit dem USB umgehen. Ein wenig Uğraştırsada wegen der kurzen Zeit für viele Beispielanwendungen rund um USB-Ding herausgefunden. Ich denke, es gibt eine gemeinsame Idee im Umgang mit USB. Weil ich nicht über diesen Artikel oder den Artikel gelesen habe. Nun, zuerst ein paar Anwendungen korkutsada der USB nach dem Auge unterscheidet sich wirklich von RS232-Kommunikation in Bezug auf die Bequemlichkeit.
Jetzt, meine Bewerbung
Das System ist sehr einfach. Abhängig von der Temperatur sendet der Temperatursensor DS1820 Sicaklik Sensorü RA5 pic18f4550, PIN-Informationen, und sendet sie über den USB-Anschluss an den Computer. Für jetzt nur sendet an den Computer. Ich bin ein wenig mehr für die Anfänger noch C # Form und zeigte die Form nur, um die Temperatur der Kommunikation mit dem Bild zu zeigen.
Great project!!!
Is there any way to send data from PC to PIC , or any usb hid library documentation?
something like that
byte[] data = new byte[64];
data[5] = usbHidPort1.OnDataSend()
Thark you, Eduard
