Especially those used in LED signage is an enhanced version of the animation card has 40 outputs to the circuit board PIC18F452 microcontroller outputs 5 sadder 74ls595 irf540n MOSFETs are used in the multiplexed output irfz44 used instead. Set the dip switch can easily be found on the circuit is being run with different animations. The project started ares proteus isis simulation and PCB drawings are also the source code through PicBasic’s …
Author: @FANCY – Thanks to people who contributed to preparing. Source: elektrobilim.org Alternatif link:
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-19003.zip
Publication date: 2012/05/26 Tags: led projects, microchip projects, microcontroller projects, picbasic pro examples
Battery Charge Circuit 10Ah 200Ah Power Mosfet
battery charging circuit faster than makes charging and BUZ11 mosfet power through a high circuit .. Charging circuit CD4013 based on the PR1 10K Potent with the output voltage can be adjusted if the battery kept charged continuously if the 13.8V charge and directly used and still be charged if the 14.4v charge voltage recommend anyway which is standard in the ..
