Other integrated circuits based on measurement of pic 16f88 share the ICL7660 and MCP6022 until I switched the engine RPM measurement is used in the section added source 🙂 lcd display assembly için2x16 asm, hex software and had eagle pcb drawing
RPM Module LM358 on the main circuit board in a simple circuit can be added as an additional module
- 3.6 to 25 Volts
- 0 to 51 Amps
- 0 to 999 Watts
- 2000~65000rpm, 2~6 blades
- Hold button
WattMeter Circuit
Source: homepages.paradise.net.nz Watt, Current Meter Circuit PIC16F88 RPM Sensor alternative link
Åžifre-Pass: 320volt.com
Publication date: 2009/12/24 Tags: microchip projects, microcontroller projects, pic16f88 projects
Portable ECG Data Logger MSP430F1232 LCD
Advanced circuit is quite complicated though most of us can not apply electronic medical medicine but all shared resources software, technical drawings, etc. protel drawings. integrated into the main control used with Texas Instruments MSP430F1232 microcontroller different
ECG Data Logger Project
The objective of this ECG Logger project, sponsored by Intellidesign Pty. Ltd., is to design two ECG holter monitors which meet the standards required for medical devices. One of the devices will have a wireless link, whilst the other will be approximately the size of a credit card.
