Thermocouple Reading Circuit PIC16F877
| Updated on August 3, 2019
Thermocouple reading circuit PIC16F877 microcontroller based on the C source software, isis proteus simulation files and eagle diagram, printed circuit boards have drawings. Thermocouple voltage 0V (0 ° C) and 42.92mv (760 º C) 4.8mv (5/1024) on a PIC16F877 8-bit resolution ADC resolution 10bits DAC.
pic16f877-adc-pid-plc-s7-300-termokupl
Thermocouple General Information
Thermocouples -200 ° to 2320 ° C is widely used in various processes. Thermocouples two different metal alloys, obtained by welding the ends of the temperature measurement element. The point boiled HOT SPOT , the remaining two open ends COLD SPOT is called. With thermocouple cold junction temperature difference between the hot spot is formed. Proportional to the temperature difference voltage in mV at the ends of the cold spot is produced. With hot spot no matter how cold spot temperature distribution of the generated voltage is proportional to the temperature difference between the hot and cold spots
Source: cristpalma.blogspot.com/2011/05/termocupla-simatic-s7-i-parte.html alternative link:
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-18912.zip
Publication date: 2012/05/16 Tags: , ,
1 Comment “Thermocouple Reading Circuit PIC16F877
    MOC3041 12 Channel Isolated Triac Module
    Several control applications lamp, motor, electronic devices, etc.. you can use 12-channel isolated triac MOC3041 motorola module card .. Insulation work done by theriac drive instead of being used BT136 BT138 triacs or leg connections matching the triac used. Look circuits, uncluttered layout elements idc types of signal input through the socket while the other parts are made out of two terminals `s ..
    Meanwhile triac metal parts of the case are associated with a central leg in these areas are high-voltage circuit, be careful when running tests
