Digital Tone Control Circuit with PIC16F877 LM1036
| Updated on June 30, 2023
Were made by combining the LM1036 integrated circuit PIC16F877. BASS, TREBLE, BALANCE, VOLUME settings on the LCD screen is made in my image as a 15 something in the shade echelons. In addition, this circuit easily adapted to integrate other tonkontrol eqlayz integrated holster or connected. 4 separate circuits can be added to any channel.
The working principle is very simple. Four separate 4-bit digital data is collected and converted to the number of analog output resistance of the common 0V … 5V voltages are given in 15 different stages. This voltage is applied to the input level of the integrated tone control.
LM1036 stereo audio tone is an integrated analog voltage to control. 0ver … 5.4 v input voltage level at the output voltage is suitable for this level PICs. Mode button on the screen each press BASS, TREBLE, BALANCE, VOLUME Remove writings. next number of this article shows the level of voice with a number between 0 … 15. the level bar on the bottom line seems to be.
pic16f877-ton-kontrol
pic16f877-lm1036-ile-dijital-ton-kontrol-devresi-sema
Digital Tone Control Circuit proteus isis simulation schematic pic assembly source code
Publication date: 2008/01/12 Tags: , ,
4 Comments “Digital Tone Control Circuit with PIC16F877 LM1036
    Scrolling LED Text Circuits PIC16F84 PIC16F628 PIC18F452
    PIC16F84, PIC16F628, PIC18F452 circuits made ​​with 16 32 60 Column Marquee isis proteus simulation files are one of many circuits can simulate. Source codes and codes on the circuit’s writing projects can be done by modifying the different advanced rock. Thanks to those who contributed to preparing
    Made with 32 column marquee 8X32 PIC16F628 pic basic
    Keyboard Controlled assembly 24 columns marquee with PIC16F84
    PIC18F452 pic basic 60 column marquee
    PIC16F84A 8 × 17 + 112 LEDs LED marquee assembly
    PIC16F628 with 16 column marquee c language
    Marquee Display assembly with PIC16F84 16
    Digitaler Tonregelkreis mit PIC16F877 LM1036
    Wurden durch Kombination der integrierten Schaltung PIC16F877 LM1036 hergestellt. Die Einstellungen für BASS, TREBLE, BALANCE, VOLUME auf dem LCD-Bildschirm werden in meinem Bild als 15 Etwas in den Schattenebenen vorgenommen. Darüber hinaus ist diese Schaltung leicht an die Integration anderer Tonkontrol eqlayz integrierter Holster angepasst oder angeschlossen. Jedem Kanal können 4 separate Kreise hinzugefügt werden.
    Das Arbeitsprinzip ist sehr einfach. Vier separate digitale 4-Bit-Daten werden gesammelt und in die Anzahl der analogen Ausgangswiderstände der gemeinsamen 0 V… 5 V-Spannungen umgewandelt. Diese werden in 15 verschiedenen Stufen angegeben. Diese Spannung wird an den Eingangspegel der integrierten Klangregelung angelegt.
    Der Stereo-Audioton LM1036 ist eine integrierte analoge Steuerspannung. Für diese Pegel-PICs ist ein Eingangsspannungspegel von 0 über 5,4 V bei der Ausgangsspannung geeignet. Drücken Sie die Modustaste auf dem Bildschirm, und drücken Sie jeweils BASS, TREBLE, BALANCE, VOLUME. Entfernen Sie die Schriften. Die nächste Nummer in diesem Artikel zeigt die Sprachlautstärke mit einer Zahl zwischen 0 und 15. Die Lautstärkeleiste in der unteren Zeile scheint zu sein.
  3. Oscar LópezOscar López
    IGITAL TONE CONTROL CIRCUIT WITH PIC16F877 LM1036
    Thank’s for your projet interesting……Could you help to me with pasword for 85.zip
    Thanks in advance
