Prototyping Board for PIC16F876 Programmer, Experiment
| Updated on July 14, 2023
Prototyping Board for PIC 16F876 testing for PIC16F876 With this circuit board, you can program your microcontrollers from 16F87X family and the 18FXXX comprising 28 pins.
this arrangement allows you to test its operation without having to remove the component (PIC) of the motherboard created. You should then make cards from the connectors available. On each of the connectors, we find the various inputs / outputs of microcontrollers. We must keep in mind that I create for this circuit test a PIC 16F876. This means that if you want to use another PIC platinum with this test, it will check its pin before use itself.
PIC16F876 Prototyping Board
pic16f876prog-test
Source: namselectro.free.fr/ PIC16F876 Prototyping Board schematic pcb files alternative link:
Publication date: 2008/10/27 Tags: ,
1 Comment “Prototyping Board for PIC16F876 Programmer, Experiment
    Quality Preamplifier Circuits
    Preamplifier 10 to six channels for SACD and Home Cinema The preamplifier to six lanes that we present is intended to pilot a HI-FI to five or six channels. You will appreciate the quintessence of new SACD or simply to give tone to your Home Cinema”.”He will find its place in your system if your player does not have volume control. This project is the first part of a project comprising a series Monoblock Power 5-way tube that will be presented in our editions.
