LCD Display Counter Circuit with PIC16F84A Picbasic Pro
| Updated on July 13, 2023
In this circuit, the PIC16F84A microcontroller and 16X2 digit counter 12 is made using LCD screen. SWITCH button LCD each signal sent from the values ​​of a which provides enhanced. If the RESET button on the LCD allows the values ​​reset.
LCD Display Counter Schematic
lcd-sayici-devresi-150x150
LCD Display Counter Circuit PCB top
lcd-sayici-devresi-ares-pcb-150x150
Counter Circuit picbasic pro source code and proteus pcb, simulation files:
Publication date: 2008/10/16 Tags: , , ,
1 Comment “LCD Display Counter Circuit with PIC16F84A Picbasic Pro
    0-9999 Counter Circuit with PIC16F84A Picbasic Pro
    This Counter Circuit and the microcontoller 7-segment display using PIC16F84A 0-9999 counter circuit is formed. Plus (+) button to increase counter value minus (-) button allows the reduction. RESET button will reset the value in the counter.
    0-9999 Counter Schematic
