PIC16F84 LCD Display LC Meter
| Updated on July 14, 2023
PIC16F84 LCD Display LC Meter circuit Box front waisted measure be careful when buying the box to cut the picture box paste it on top and falçata or drawing a knife then stop in the box bourdu to keep the four M3 screws and nuts, use Bordt USING the reader relays internal diode line is I’m a little late, I realized I did board relay leg reverse came first problem was that but in the scheme and BoardTM fix but I still protection diode I used the relay of different uses for kaldırmadım.pow source 12 Volt DC Jack (interior +) (outer portion of the Gnd)
I’ve used for testing terminal born request you make the connection, but the cable is too long to keep going to use.
Also I do jumper in a description:
J1: 16 × 1 LCD for those who want to use
J2: Frequency test
J3: Background light
Circuit Diagram, Box Size, Box Section, Box Cut Method
l-c-metre-devre-semasi-150x150 pic16f84-l-c-metre-kutu-olcu-150x150 pic16f84-l-c-metre-kutu-kesim2-150x150 pic16f84-l-c-metre-kutu-kesim-metodu-150x150
Box Cut, Cut Adapter Input, Internal Structure, PCB Bottom
pic16f84-l-c-metre-kutu-kesim-150x150 pic16f84-l-c-metre-adaptor-giris-kesim-150x150 pic16f84-l-c-metre-ic-yapi-150x150 pic16f84-l-c-metre-pcbalt-150x150
PCB Top, Alignment, 2×16 LCD, Toggle Switch
pic16f84-l-c-metre-pcb-ust-150x150 pic16f84-l-c-metre-yerlesim-150x150 pic16f84-l-c-metre-16x2-lcd-150x150 pic16f84-l-c-metre-toggle-switch-150x150
Empty Test, Frequency Test, L Mode, 10μh Test
pic16f84-l-c-metre-bos-test-150x150 pic16f84-l-c-metre-frekans-test-150x150 pic16f84-l-c-metre-l-mod-150x150 pic16f84-l-c-metre-10uh-test-150x150
680μh test, 27pF SMD Test
pic16f84-l-c-metre-680c2b5h-test-150x150 pic16f84-l-c-metre-27pf-smd-test-150x150
LC Meter circuit eagle schematic pcb and hex code files
Publication date: 2008/11/02 Tags: , ,
1 Comment “PIC16F84 LCD Display LC Meter
