Hello Friends
For a long time I did not do my share. I looked at my little library amusement park six months ago I prepared for bi TRIAC 8 Channel 24 saw the animated card. Obviously things I’d forgotten due. After getting a bit of project files I thought I’d share with you.
Card design for amusement parks like I did. More than ever animated card did not come no one complained. Is working without a problem.
In general, if you need to talk a little circuit on the circuit triac BTA24 600BW as I used. According to the triac 25 A current catalog information and can withstand up to 600V for example. Triac MOC3020 to drive the triac driver I used in the optical isolator. Processors have the PIC16F628.
I made a special request for software-olarakda did not have much of a variety of animation. Today we get a bit of software I’ve added two more animations a spend. Now it was a little more satisfying.
Attention bta24 A2A body with legs is still isolated from each other. So without isolation can connect together in one cooler. When connecting to the cooler, use of heat conduction paste. You can also use the BTB24 triac triac but this leg of the A2 with each other with the transmission housing. So do Triac single coolant from the coolant to connect you will need to isolate. Otherwise, you may experience poor results. Also on the PCB in particular payload, more precisely to do high current passing through roads with a thick layer of solder is the way you need to thicken. Otherwise, copper path alone may evaporate at high current. 🙂
Triac Animation Card belongs to the PCB, schematics and source code files:
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-18977.zip
Publication date: 2012/05/22 Tags: microchip projects, microcontroller projects, pic16f628 projects
Phone Rings Lamp Circuit MOC3020
The circuit in the picture when connected to a telephone line with any incoming calls will allow the lamplight. Circuit is in two parts and the two circuits are separated from one another by MOC3020 optocoupler. MOC3020 Optocoupler, without an electrical connection between the low voltage with high voltages and currents can control is called circuit elements. Lower portions of the first circuit is to be connected to the telephone line.
