Hello friends, I have done well to share with you the counter circuits as functions istedim.kısa tell. There are three mode of counter:
enc: millimeter accuracy in the measurement is made. The value is set in the output data.
Counter: Counts the amount is set at the value of the output data.
disp: Meter makes measurement, shows decimeter accuracy
You can connect to the encoder input, interrupt b0 rises from 0 to 1 at the moment in a direction B output is 0 if one is going in the other direction. I do not know, but these commands can be prepared from the PLC logic business benefits
example of output at a low level to high levels (Low-to-High) transition in the B output of availability if one direction while rotating B-> LOW other direction while rotating B-> HIGH so that it becomes the direction in which return you will understand that the output of the Low-to-High transitions a If B is looking at the state variable increases HIGH, LOW detract from the
Note: PIC16F628 Set the frequency of 20MHz.
PIC16F628 Counter Circuits Schematics
To be @ Picproj forum’s sharing all of the source files in hex isis simulation eagle pcb’s ccs c code and other files
PIC16F628 Counter Encoder Manual
PIC16F628 Multi-Mode Encoder proteus isis simulation schematic proteus ares pcb and CCS C source code files download:
Publication date: 2009/01/26 Tags: ccs c examples, microchip projects, microcontroller projects, pic16f628 projects
PIC16F84 Simple PICmicro Web Server
I’m curious and I want to try a project with the web server 16f84 project has two circuits in series and parallel port connection and circuit eprom 24c256 eeprom used pic and communication can be pic assembly examples
