Scrolling Text Circuit LED Matrix PIC16F628 74HC595
| Updated on August 3, 2019
Marquee circuit built on the pic16f628 microcontroller circuit 8 X 80 LED matrix used LEDs is being prepared with the source software assembly circuits 74HC595. asm, cod, etc. have proteus isis simulation file. marquee circuit computer with rs232 interface for the despatch of an advanced case of kom port communicates using the terminal program.
LED Marquee PIC16F628 This unit plays the text on the LED matrix 8 X 80 LEDs, has a memory 128 characters of text, which are loaded from a PC via COM port using Terminal V1.9. The device has all the uppercase and lowercase letters of the Russian alphabet and numbers, and other characters that you can see in the table below. MCU running at 20 MHz and operates the shift registers 74HC595D, that the logic level 1 lights LED matrix rows and decoder full analog controls through 74LS138 amplifying transistor 8-mu columns of all matrices.
terminal-programi-kayan-yazi
led-marquee-circuit-proteus-isis-leds
Source: cxem.net/mc/mc147.php alternative link:
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-19689.zip
Publication date: 2012/09/08 Tags: , ,
2 Comments “Scrolling Text Circuit LED Matrix PIC16F628 74HC595
    Op Amp In Stereo Hi-fi Tone Control Circuit
    Stereo tone control circuit bass, treble, balance and volume controls OPA2107 op amp is not used in the original series pretty open is frequently used in high-quality professional audio applications not found in the market place TL072, NE5532 opamps used. HiFi tone control circuit’s PCB drawing and layout diagram does not have a circuit is not complicated, but actually supply circuit has a bit muddled mess
    Circuit power supply 2x15v symmetric 7815 and 7915 regulator IC used in the power supply 2 toroidal transformer is used regulator solid same 2 made ​​OPAMPs separate fed essentially a single transformer enough so that we know the classic symmetrical supply circuit is adequate but that’s hi fi, quality and so on. 🙂 When we go into detail sounds a bit complicated and costly electronics …
    Lauftext Schaltung LED Matrix PIC16F628 74HC595
    Marquee-Schaltung auf der Pic16f628-Mikrocontroller-Schaltung gebaut 8 X 80 LED-Matrix verwendet LEDs mit den Source-Software Assembly-Schaltungen 74HC595 vorbereitet wird. Asm, Kabeljau usw. haben eine Proteusisis-Simulationsdatei. Marquee-Circuit-Computer mit RS232-Schnittstelle für den Versand eines Advanced Case von Kom-Port kommuniziert mit dem Terminal-Programm.
    LED-Laufschrift PIC16F628 Dieses Gerät spielt den Text auf der LED-Matrix 8 X 80 LEDs, hat einen Speicher 128 Zeichen Text, die von einem PC über den COM-Anschluss mit Terminal V1.9 geladen werden. Das Gerät enthält alle Groß- und Kleinbuchstaben des russischen Alphabets sowie Zahlen und andere Zeichen, die Sie in der folgenden Tabelle sehen können. MCU läuft bei 20 MHz und betreibt die Schieberegister 74HC595D, dass der Logikpegel 1 LED-Matrixzeilen und Decoder voll analoge Steuerungen durch 74LS138 Verstärkungstransistoren 8-mu-Spalten aller Matrizen beleuchtet.
