PIC12C509 Remote Receiver Transmitter
| Updated on July 5, 2023
Summary infrared remote control for video and television transmitter sent from the terminal and control code to determine, on, off, and can be reversed. NEC Matt Howe Institute consumer electronics products that conform to the transmitter, if possible on most operating there, in our multi Sony verify remote control transmitter manufacturer, Matsushita, Hitati, Toshiba, NEC, sanyo, Victor, a television remote control operates the Pioneer, Sony, Mitsubishi, Sharp is a little different for Matt Howe work.
pic12c509_remote_alici
pic12c509_remote_verici
Summary 10 domestic appliances (eight) code system response, 6 (3) up to any one of the keys to the code system which can be assigned to the infrared remote control transmitter.
Source: interline.or.jp PIC12C509 Remote Receiver Transmitter all files alternative link:
Publication date: 2008/03/07 Tags: , ,
2 Comments “PIC12C509 Remote Receiver Transmitter
    PIC12F629 PWM SMPS Control
    PIC12F629 microcontroller is done with PWM Control GP0, GP1 output MOSFETs with BUK555 in the SMPS transformer EI33 if sülü. 25kHz operating frequency of the circuit tests made ​​with 50w load. ATX SMPS power supply transformer ei33 from the author of deploying and re-festooned dressing.
    It is a chopper to 25 kHz built around a PIC12F629 to operate on a 12V battery.It uses a transformer recovered in a power PC.The holding power has been tested up to 50 W, the secondary is wound depending on the need
    PIC12C509 Fernempfänger Sender
    Zusammenfassung Infrarot-Fernbedienung für Video- und Fernsehsender, die vom Terminal gesendet wird, und Steuercode zum Bestimmen, Ein- und Ausschalten sowie zum Umkehren. NEC Matt Howe Institute Unterhaltungselektronik-Produkte, die dem Sender entsprechen, wenn möglich auf den meisten dort betriebenen, in unserem Multi-Sony-Fernbedienungssender-Hersteller, Matsushita, Hitati, Toshiba, NEC, Sanyo, Victor, eine Fernsehfernbedienung bedient den Pioneer, Bei Sony, Mitsubishi und Sharp sieht die Arbeit von Matt Howe etwas anders aus.
