Periodic Ruler circuit with PIC16F877
| Updated on August 4, 2019
At the request of a friend, ‘science and technology’ magazine published in electronic schematic and printed circuit board of the LCD display, I rearranged the periodic table. To our friends that may need an application usually student. System analysis, etc. can be implemented as a project in class.
Ruler circuit project
bilim-teknik-elektronik-periyodik-cetvel-devresi-1
bilim-teknik-elektronik-periyodik-cetvel-devresi-2
bilim-teknik-elektronik-periyodik-cetvel-devresi-3
bilim-teknik-elektronik-periyodik-cetvel-devresi-4
bilim-teknik-elektronik-periyodik-cetvel-devresi-5
Proteus Ares pcb and circuit simulation schema files of the Periodic rule:
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-25442.zip
Publication date: 2016/04/22 Tags: ,
2 Comments “Periodic Ruler circuit with PIC16F877
    Additional Card Module For Microcontroller Projects
    The author uses AVR microcontrollers, but has a structure that can be used with different microcontrollers.. button, LED, switch, LCD, etc. gather the cards together and made a single card as well as passive recreational module
    – Keyboard Matrix (number of rows – 4, number of columns – 4);
    – Chapter separate and independent buttons (number of buttons – 16);
    – DIP-switch (the number of independent control lines – 32)
    – Number of encoders – 2 a clock you can use the encoder with the button);
    Periodische Herrscher Schaltung mit PIC16F877
    Auf Antrag von einem Freund, “Wissenschaft und Technik” – Zeitschrift, veröffentlicht im elektronischen Schaltplan und Leiterplatte der LCD-Anzeige, die ich neu arrangiert der periodischen Tabelle. Unsere Freunde müssen eine Anwendung in der Regel student. System-Analyse, etc. umgesetzt werden können, wie ein Projekt in der Klasse.
    Lineal-Schaltung-Projekt
