Sierpinski Triangle in Mathematics (Sierpinski Triangle) there was such a thing .. the author of this triangle fractal remove PCBs on a plaque made WiFi antenna. Linksys WRT54GS modem’s power of attraction has increased up to 500 feet. Sierpinski triangle pcb copper clad sticker printing on both sides of the copper plate on the other side is making a face while using it as a complete chassis. Antenna RP TNC Jack connector with cable included balendajl Sierpinski triangle at the end of the solders. Application of the Sierpinski triangle has pcb drawings. Author PCB laminating machine used for printing
Source: andrewhazelden.com/blog/2011/02/homemade-sierpinski-gasket-fractal-wifi-antenna pcb ve diğer dosyalar için alternative link:
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-19788.zip
Publication date: 2012/09/16 Tags: interesting projects electronics
Transformerless Led Lighting Energy Saving Led Lamp Circuits
Previously LED lighting related energy-efficient LED lamp my project I shared a simple circuit and mains voltage lowers pointed the white LEDs overworked .. This article, the circuit in the same structure 12 led lamp, 36 LED lamps and 160 LED lamp circuits are circuits in china goods lamp was removed from . Mains voltage LEDs run directly without isolation capacitors reduce the efficiency is not healthy, but slightly lower at very cheap and can work without problems for a long time that there’s so many LED lamp model is based on the same system all
If you pay attention in circuits 220v entrance EMI filter inductor, capacitor used the reason to reduce costs further circuit boyutuna have the effect of adding filters work if you would be better to also makes the circuit after the current being drawn by the fair value of insurance users to add remember
Sierpinski Dreieck Fraktale Antenne Wifi machen Leiterplatte
Sierpinski Dreieck in Mathematik (Sierpinski Dreieck) gab es so etwas .. der Autor dieses Dreiecks Fraktals entfernen Leiterplatte auf einer Plakette WiFi-Antenne gemacht. Die Anziehungskraft des Linksys WRT54GS-Modems hat sich auf bis zu 500 Fuß erhöht. Sierpinski-Dreieck-Leiterplatte kupferner plattierter Aufkleber, der auf beiden Seiten der Kupferplatte auf der anderen Seite druckt, macht ein Gesicht beim Verwenden es als komplettes Chassis. Antenne RP TNC Jack Stecker mit Kabel enthalten balendajl Sierpinski Dreieck am Ende der Lote. Anwendung des Sierpinski Dreiecks hat PCB Zeichnungen. Leiterplatte Laminiermaschine zum Drucken verwendet
