PC Power Supply Card (installed into the computer)
| Updated on July 2, 2023
Simple works you can use in 3 volts … 12 volts for the PC Card Power Supply has two different design. Fitted within the computer because you do not need to use additional boxes
LM317 power supply circuit
lm317_pc
Voltage adjustment circuit 500 can provide power to the LM317 series resistance group is done by connecting to the ADJ Pin
lm317_ayar
lm317_devre
2N3055 power supply circuit
2n3055_pc_kart
Control Element TL431 Circuit 1.5A power can give the voltage setting the ADJ pin connected series resistance group, the output of the binding is provided by this circuit in your hand> 2N3055 if there is to assess done ๐Ÿ™‚ If there is no circuit PCBs by modifying the LM317, I suggest using the LM317 with the same difference is even more powerful
lm317_lm317k
2n3055_devre
Finally, the quality is not too strong on your computer Power Supply ๐Ÿ™‚ Made with 1.5 2N3055 circuit that powers the full power draw at full power loads do not recommend that you use the connect circuit made โ€‹โ€‹with LM317 more appropriate if you are using standard powersupply
PC Power Supply Card schematics psb all files:
ลžifre-Pass: 320volt.com
Publication date: 2008/01/12 Tags:
1 Comment “PC Power Supply Card (installed into the computer)
    Remote Extender Circuit
    With this circuit, Control devices (tv, vcd, dvd etc.). Different from long distances or from the control room can
    I will send signals that control circuit (IR Extender) reaches circuit receives signals copies ๐Ÿ™‚ and connected to the output of other devices with infrared LED controls
