I’m doing the drill bit from the syringe needle in my hand I had a lot of plastic parts that have lost their function as foam probe tip my hand I have done in terms of evaluating syringes friends who use the same method can do. easy to make practical and useful.
I’ve included it at the press idle krakodil bi-capped probe was ultimately get auspicious auspicious 🙂
Note: I cut the ends of doing it again I’ll use the drill bit.
Published: 2011/05/21 Tags: interesting projects electronics
6W Tube Amplifier Project Single Ended EL84 6P43P ECC83 Circuit
Hello friends for a long time I worked on the amp my bitirdim.yaklaşık 1-2 years, tube amps and research and my work had, especially in Turkey, says the industry tube amps much about missing that we ( I think this lack , and only the lack of research and Uras caused by lack of will ) I thought this alandada a amp to do , at least it was planning to konudada information .
I have labored so long and at the end of my Uras results I have achieved some positive results . I’m sure many of our friends who want to work on this issue , there are those who even was even , that it sebeptendir now I share it with you here on my work .
