Hifi Amplifier Mosfet RAS300 RAS100 PCB drawings
| Updated on August 3, 2019
Design Nico Ras belonging to diyaudiotr.com site RAS300 300w mosfet power (100w and shared RAS100 amplifikatörlerine I share my PCB drawings belonging to the PCB drawings created with proteus in addition to ares ros300, you can use the same circuit inside the power supply circuit diagram in ras100
Hifi Amplifier Mosfet RAS100 New PCB Design;
100w-mosfet-amp-ras100-proteus-ares
Hifi Amplifier Mosfet RAS300 New PCB Design;
300w-mosfet-amp-ras300-proteus-ares
Note: ras100 and ras300 new pcb drawings has not been tested with the original file contained in the schema compare and make the circuit
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-20954.zip
Publication date: 2012/12/23 Tags: ,
3 Comments “Hifi Amplifier Mosfet RAS300 RAS100 PCB drawings
    An Interesting Class D Amplifier Design Regulated 220V 2X60W
    Features Class D amplifier circuit for high power bass sound pretty cheap, size, weight, etc.. bakımındn that it is advantageous for a lot of voiceover projects are used in audio quality is not high … In this project, 2x60W Class D amplifier circuit to operate the direct 220v regulated regulated power floor moc3010 associates drive optocouplers and Q4015L5 15 Amp Triac based on the circuit there and 51V dc output gives the voltage they zen-25.5v + with + -12 and partitioned as a single 12v class d amplifier is operated
    Hifi-Verstärker Mosfet RAS300 RAS100 Leiterplatte Zeichnungen
    Design Nico Ras gehört zu diyaudootr.com site RAS300 300 watt mosfet power (100w und shared RAS100 amplikatorörnerine teile ich meine PCB Zeichnungen gehören zu den PCB Zeichnungen erstellt mit Proteus zusätzlich zu ares ros300, können Sie die gleiche Schaltung im Netzteil Schaltplan verwenden in ras100
    Hifi-Verstärker Mosfet RAS100 Neues Leiterplatte-Design;
