development on the board64 pin pic24fj64ga006 pic24hj128gp506 the same leg connection with a PIC24 series microcontrollers available on the circuit inputs and outputs for connection and Pickit2 Clone header for used FTDI TTL 232R 3V3 USB to serial cable spacing from there also on the processor used standard passive materials (resistance filter capacitors, etc.). ‘s. Breakout board for PIC24 and schema files are eagle pcb.
Source: reesemicro.com/Home/projects/pic24-64-pin-breakout-board alternative link:
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-18297.zip
Publication date: 2012/01/13 Tags: pic development board
Programmable Automation PIC16F87X Electronic PLC Circuit
Several automation, control circuits I’ve seen, but so far so many features to an existing application the first time I met with microcontroller plc have done .. especially smart home alarm or for different projects that can be used for a circuit on the card has 8 channels via these channels a variety of devices control can be computer connection is provided via the serial port have programs for win7 and xp on the bright side of this program in C + + source code through there.
