These circuits using CCS C Compiler and use of LM35 temperature sensor includes menu design on Graphic LCD. Menu selection, etc., especially on graphic LCD. one of the rare examples of issues on the Internet. (I call this menu control in this manner until the time that I could not find a sample circuit 😀 hdm64gs12.c Driver did some changes in the file if a problem during operation of the CCS C program files directory, copy the Drivers folder.
Unfortunately, only measure the temperature and the menu shows the code block can share the screen. Other parts can program it yourself or you can remove from the menu.
LM35 PIC16F877 Temperature Graphic LCD
LM35 PIC16F877 Graphic LCD thermometer project schematic source code files:
Åžifre-Pass: 320volt.com
Publication date: 2009/08/21 Tags: ccs c examples, microchip projects, microcontroller projects, pic16f877 projects
dSPIC Wav Recorder Wav Player Project
Circuit DSPIC33FJ64GP802-I/SP software has a micro-controller based on the hex, but unfortunately do not have the source code for the microcontroller DSPIC with the series level at least because of resource constraints of hardware design department can give more or less the idea.
MMC-SD-SDHC memory card with DSPIC `s communications, key combinations, microphone input and output processing, feeding floors, DSPIC IR communication all in one collected in a project of this type of design for your studies can be an example
dSPIC Wav Player
