Microcontroller LED Matrix Studio is an application designed for electronic enthusiasts who want to accelerate the development of LED and matrix projects. Many different export options support animations and different matrix sizes. It can be used to design fonts, graphics and animations for PICAXE, PIC, Arduino, Parallax and other electronic or micro controller projects. An example of the use of exported data comes with Arduino files. Sure Electronics used 32×8 and 24×16 LED panels, Adafruit 8×8 dual color matrix, custom LED matrix and general 8×8 / 5×7 monochrome matrix. There are applications in the Zip archive, several sample matrices, presets and a sample arduino project ( Adafruit 8×8 for bicolour matrix ).
The latest version is shared with Delphi 2007 source code.
Led Matrix Studio Features
Supports matrices from 1×1 to 64×64
Supports single, two color and RGB matrices
Square or round pixel
Three brush sizes (1 pixel, 2×2 and 3×3 pixels)
Highly customizable export modes (including “Sure 24×16” format) and binary Frame-based undo / redo (infinite levels!)
Seven different drawing modes + copy / paste
Turn a matrix upside down, make a mirror, turn it over, turn it, slide it
Animation support, unlimited number of frames
Font designer / font viewer
More than one user memory
Import from bitmap image
Exporting to a bitmap image
Automatic saving option (2, 5 and 10 minutes) Easy to use
Preview in X1, x2, x3, x4, x5 and x6 dimensions
Code templates, automatically generate code of operation!
Get rid of those graphic papers and calculator forever!
source: maximumoctopus.com/pc/ledmatrix.htm
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-25926.zip
Publication date: 2018/06/10 Tags: electronics software tools
Led Matrix Studio Arduino, Microchip
Microcontroller LED Matrix Studio ist eine Anwendung für elektronische Enthusiasten, die die Entwicklung von LED- und Matrix-Projekten beschleunigen möchten. Viele verschiedene Exportoptionen unterstützen Animationen und verschiedene Matrixgrößen.
Es kann verwendet werden, um Schriften, Grafiken und Animationen für PICAXE, PIC, Arduino, Parallax und andere elektronische oder Mikrocontroller-Projekte zu entwerfen.
Ein Beispiel für die Verwendung von exportierten Daten kommt mit Arduino-Dateien.
Microcontroller LED Matrix Studio est une application conçue pour les passionnés d’électronique qui souhaitent accélérer le développement de projets LED et matriciels. De nombreuses options d’exportation différentes prennent en charge les animations et les tailles de matrice différentes. Il peut être utilisé pour concevoir des polices, des graphiques et des animations pour PICAXE, PIC, Arduino, Parallax et d’autres projets de contrôleur électronique ou micro. Un exemple d’utilisation des données exportées est fourni avec les fichiers Arduino. Sure Electronics a utilisé des panneaux LED 32 × 8 et 24 × 16, une matrice bicolore Adafruit 8 × 8, une matrice LED personnalisée et une matrice monochrome 8 × 8/5 × 7 générale. Il existe des applications dans l’archive Zip, plusieurs exemples de matrices, des préréglages et un exemple de projet arduino (Adafruit 8 × 8 pour matrice bicolore).
La dernière version est partagée avec le code source de Delphi 2007.
