12V 24V Solar Panel Regulator LCD Display
| July 12, 2023 Updated
The Solar Panel Regulator measures the voltage or charging current on your solar cell and cuts off the energy of the panel to stop overcharging. It works with 12V or 24V systems.
The screen with 3.5 digit liquid crystal display is driven by ICL7106. This integrated is used in many measuring instruments in the market, thanks to the switch on the circuit, either current or voltage information is displayed on the screen. Solar Panel Regulator circuit is used in 80w panel.
The pcb (.ddb) design of the Solar Panel Regulator circuit was prepared with protel.
Solar Panel Regulator Project
gunes-paneli-regulator-devresi-80w-panelde-icl7106
Source: http://www.siliconchip.com.au/cms/A_103353/article.html
12V 24V Solar Panel Regulator schematic PCB alternative link:
Published: 2008/09/04 Tags:
1 Comment “12V 24V Solar Panel Regulator LCD Display
