Laboratory Power Source LM338 0-30V 30A MJ15004
| Updated on August 4, 2019
Given that quite actively interested in the construction of power supplies power amplifiers, as well as for the design of switching and linear power, so I embarked on the design and subsequent construction of a linear power supply with parameters advising the construction of the category of “laboratory”, mainly due to the scope of regulation voltage range of 0V – 30 (35V), the maximum allowable current consumption 30A, which can additionally select sampling voltage directly from the source, when no load current not limited to the boundaries 30A (internally structurally restricted) and remove the voltage across the current-limiting fuse with a current in the range of 15 mA – 20A (30A). These parameters show of excellent noise suppression, very small ripple output voltage and output voltage stability. Source is also able to work with large output currents even if you set the minimum output voltage, due to the proposed election voltage transformer in cooperation with komparačním 15V/30V circuit. LM338
MJ15004 LM338 Power Source Main Schematic
mj15004-lm338-power-source-main-schematic
linear-power-supply-lm338-0-30v-30a-transformator
I decided this design complemented by a symmetrical voltage source with output voltage options (± 9V, 12V, 15V, 18V) enabled 3A max current consumption. The entire structure is complemented by a series of auxiliary circuits, which include the control unit ventilators for reliable cooling of active semiconductor devices and resources in case of heat Overload automatically disconnects power branch circuit PROTECT TEMP,
0-30V 30Amp Laboratory Power Source schematic pcb files download:
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-25284.zip
Publication date: 2014/07/03 Tags: , ,
2 Comments “Laboratory Power Source LM338 0-30V 30A MJ15004
    Intelligent 1Ah – 55Ah Battery Charger Circuit UC3906
    The charger circuit is equipped with a special integrated circuit UC3906, which can check the battery status in each charging cycle. Therefore suitable for charging conventional lead acid cells and batteries for hermetically. Due to the special circuit structure is simple charger while maintaining optimal performance.
    Labor Stromversorgung LM338 0-30V 30A
    Gegeben, die sehr aktiv daran interessiert, den Bau der Netzteile der Endstufen, sowie für die Gestaltung von Schalt-und Linearregler macht, also begab ich mich auf den Entwurf und die nachfolgende Konstruktion eines linearen Netzteil mit Parametern der Beratung der Konstruktion der Kategorie “Labor”, vor allem wegen der Anwendungsbereich der Verordnung Spannungsbereich von 0V – 30 (35V), die maximal zulässige Stromaufnahme von 30A, die können wählen Sie zusätzlich das Probenahme-Spannung direkt von der Quelle, wenn kein Laststrom nicht beschränkt auf die Grenzen 30A (intern strukturell eingeschränkt), und entfernen Sie die Spannung über den strombegrenzungs-sicherungen mit einem Strom in der Größenordnung von 15 mA – 20A (30A). Diese Parameter zeigen hervorragende Rauschunterdrückung, sehr kleine welligkeit der Ausgangsspannung und die Stabilität der Ausgangsspannung. Quelle ist auch in der Lage, die Arbeit mit großen ausgangsströmen, selbst wenn Sie die minimale Ausgangsspannung, die aufgrund der vorgeschlagenen Wahl Spannungswandler in Zusammenarbeit mit komparačním 15V/30V-Schaltung. LM338
