Line following Robot Sumo Robot, control circuits
| Updated on August 3, 2019
Sumo, Line following and robot control card project open source design and very high quality of all resources provided PIC microcontroller code and eagle diagram pcb drawings are especially line following robot prepared for PCB drawing a very good high strong with a system that can go very quickly 🙂
Robot control board previously shared “Rötkönen the” hardware ready style (see: Robot Robot development control board for your projects Rötkönen) PICAXE28X2 AND PIC18F25K22, PIC18F26K22 for use with microcontrollers have two different PCBs ..
Sumo robot software prepared by the MPLAB C18 based on PIC18F4550 microcontroller in addition to the robot body design drawing (dxf) there.
sumo-robot-software-design-robot-electrical-design-pcb-robot-chassis-design
Line following robot I have 3 different microcontroller for more comprehensive PCB design on a Board with the microcontroller project PIC18F25K22 software MPLAB … C18 have been prepared with source code and library files also Pic18f4550, PICAXE28X2 and AtMega328 has been prepared with the PCB, eagle, schema for drawings
line-follower-cizgi-izleyen-robot-rules-robot-games
Finally, the Robot control circuit pictures
robot-kontrol-karti-robot-controller-board
source: wiki.ottawarobotics.org alternative link:
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-21970.zip
Publication date: 2013/08/08 Tags: ,
2 Comments “Line following Robot Sumo Robot, control circuits
    Made in China Universal Charger Schematic
    Released several years ago (I’ve seen in the first resort) is a simple but very handy charger. typically known as spider or insect charging charger recharges but the strength is low long:) mechanical design in different sizes, cell phone, camera, place it in the charger the battery of the device will be a lot, etc. Charging circuit LM358 op amp is built on
    Line-folgenden Roboter-Sumo-Roboter -, Steuerungs-schaltkreise
    Sumo, Line following und Roboter-control card-Projekt open-source-design und die sehr hohe Qualität aller bereitgestellten Ressourcen PIC-microcontroller-code und die eagle-Diagramm Leiterplatte-Zeichnungen sind vor allem line-folgenden Roboter bereit für Leiterplatte-Zeichnung sehr gut hoch stark mit einem system, dass kann sehr schnell gehen 🙂
    Robot control board teilten “Rötkönen die” hardware-bereit-Stil (siehe auch: Roboter-Roboter-Entwicklung control board für Ihre Projekte Rötkönen) PICAXE28X2 UND PIC18F25K22, PIC18F26K22 für den Einsatz mit Mikrocontrollern haben zwei verschiedene Leiterplatte.
