12v dc voltage 240v dc converts to 2 different circuit. someone ir2153 with the other is crafted with 100w power output drive circuits can give tl494 floor transformer obsolete high voltage, tesla circuits made with voltage diode capacitor, we see the connection there usage restricted circuits the multiplexer also aren’t very healthy fee too but it’s a different kind of application in the archive, just in case.
Note: If the ir2153 is specified in the converter with more stable
Source: arambajk.blogspot.com alternative link:
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-19128.zip
Publication date: 2012/07/11 Tags: dc dc converter circuit, power electronic projects, tl494 circuit
MC68HC908QT4 Servo Digitizer Remote Control ASCII Data Sends
The Servo Digitizer is developed to channel control input from a model airplane radio remote control, the Futaba Skysport 4, to a flight simulator program running in a PC. It translates a pulse-width modulated signal output from the remote control into ASCII data and sends them to the PC via an RS-232 serial port. A flight simulator program in PC can use the data from the RS-232 port to control a simulated airplane in the PC. The software component of this project demonstrates the use of a source code modularity technique with a microcontroller that has limited resources.
