Traffic Light Circuit Hi Tech C Example
| September 4, 2024 Updated
Traffic light application is not different from other applications. One port is connected to multiple LEDs. When a port to connect multiple LEDs with output current of a transistor to do upgrade. When you connect a PIC microcontroller will damage the poles. LEDs which are mutually connected to the same port.
Example isis circuit drawing;
led-leds-hi-tech-c-trafikisigi-uygulama-ornegi
RB1 =! RB1; referred to the electronic discards the previous value in the opposite process is called not. Previous values ​​1 and 0, 0, 1 assigns the value. This phrase structure with the yellow light was blinking effect.
Hi Tech C Examples Traffic Light Circuit Proteus an code files :
Published: 2011/01/14 Tags: , , ,
1 Comment “Traffic Light Circuit Hi Tech C Example
